Results 1 to 7 of 7
Thread: Anyone had a Polaris 9300 for a season?
    OK, time to hear from those of you that have had a Polaris 9300 for a season. Would you buy it again knowing what you know now?
    Knowing that an actual brush on a Robotic cleans the walls and floor does it do a better job then a sweep tail?
    Your thoughts?
    Pool #1 IG 24k Diamond Brite plaster with spill-over spa. Jandy Aqua Link RS One Touch with built into pool floor cleaner. Jacuzzi Magnum pump/basket feeding Hayward top mount Zeosand filter. Jacuzzi Magnum pump/basket for Spa Jets. Heat Siphon pool heat pump. Dolphin Robotic pool cleaner.
    Pool #2 IG 35K 20X40 Vinyl. Hayward top mount Zeosand filter with Pentair 3 HP IntelliFlo VS+SVRS. Chemical Free pool using Water Doctor Copper Ion Generator, PoolSkim, Polaris 9300 Sport robotic pool cleaner, Heat Siphon pool heat pump, solar blanket, Ameri-Dome 50X30 dome enclosure during Winter.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Anyone had a Polaris 9300 for a season?
    Next year I will
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Quote Originally Posted by XsAllOverIt
    Next year I will
    Did Santa put one under your tree? Or do you have plans to get one at the beginning of the season? What was the reason for deciding to use a 9300 Sport?
    Dec 2010
    560
    I just built a new pool and the pool company recommended it. It seemed to work pretty well the few times we used it prior to winterizing the pool... When in one of the modes, it crawls all the way onto the tile.
    TFT-100 test kit
    Nov 2010
    152
    it's a good cleaner, just not worth the extra $$. The 280 will do the same job, but doesn't look as sexy. Let your wife do the sexy part & pocket the extra couple hundred bucks!
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Quote Originally Posted by Ranger987
    I think you may be confusing the 3900 and 9300 (stupid names that generate too much confusion IMO). The 3900 requires a booster pump and works essentially the same as the 280. The 9300 is a robot, which is entirely self-contained.
    Nov 2010
    152
    oops, yep, My error. I'm a little lysdexic at times too.
    APSP CST Certified
