Thread: Skimmer plate and plug or just plug? How much Anti-freeze?
    New Jersey
    98
    First time closing my fiberglass pool. Should I get a skimmer plug plus the skimmer plate cover or just the skimmer plug?
    Also how much antifreeze to purchase? intheswim.com sells a gallon that cover 10ft of 1 1/2" line. Seems like I would need a ton based on that.
    Polyquat60 (algecide)...how much is needed for a 9500 gallon pool....1 quart?
    Thanks for all the info.
    Ls
    14 x 32 Fiberglass Pool 10K gal. Hayward Pump and Sand Filter. Autopilot SWG Dig 48 and Heat Siphon 3.25sx Heat Pump.
    The Pool Calculator
    Chlorine/CYA Chart by Chemgeek
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    As far as I know, skimmer covers aren't available for inground pools. I use a gizmo in the line, an empty antifreeze bottle partially collapsed with the lid on wedged into the skimmer opening to hold the weir flat, and a bunch of cut up pool noodles in the skimmer itself and any where else that I can pack them in around the gizmo and bottle.
    For the antifreeze, buy it at Walmart for less than $3 a gallon. It will be labelled RV antifreeze, but read the label and you'll see it's for pools too. Much cheaper and no shipping. I use 4 gallons for my pool, because it only has to take care of the water that's left in the line, not the whole thing.
    New Jersey
    98
    Here is the skimmer opening cover I was talking about.
    http://www.intheswim.com/Pool-Opening-a ... und-Pools/
    The Pool Calculator
    Mar 2007
    Coastalish 'down easter'
    4,160
    Ls, before spending money on that, make sure that it will mate with your skimmer. Just from the picture I know that it's not compatible with Hayward skimmers (there are 2 extra screws)
    There's nothing wrong with skimmer doors, especially if you don't want to drain any water. I'd use the gizzmo and foam as per John's suggestion.
    Luv& Luk
    -Ted
    SW Indiana
    9,198
    Hadn't seen the inground version before. I'm not sure there is as much benefit on an IG pool since the skimmer will still hold water when the pool is winterized. You still have to protect the skimmer because it will fill with rainwater or snow.
    New Jersey
    98
    Ok thanks for the replies. I just received my custom mesh safety cover today and will soon be ready to close.
    Ls
    The Pool Calculator
