Thread: HEATWAVE Heater leaking???
    Hi
    I have a HEATWAVE heater and recently I have notices a constant stream of water from the top of the heat exchanger?
    This happen if the heater is on or not, and as a result my pool level drops by an inch or so every few days.
    It seems to be coming form a small module (about the size of a small pepper pot) on top of the exchanger. It also has a wire going into it, perhaps some kind of temp gauge?
    Q: can I seal the hole with say plumbers putty? I mean its not some sort of pressure relief valve gone wrong or anything is it??
    Sorry, cant seem to upload a pic of this.
    Help & thanks!!
    Oct 2010
    Georgia
    317
    Re: HEATWAVE Heater leaking???
    Aquacal Heatwave heatpump?
    Take a look on page 57 of the owners manual in the link below to see if the "module" that is leaking is one of the 2 types of water flow pressure switches used on these models.
    http://www.aquacal.com/images/stories/p ... manual.pdf
    AQUACAL TECHNICAL SUPPORT (727-823-5642)
    http://www.aquacal.com/technical-support.html
    Depending on the age of your Heatpump, this part may be covered under warranty.
    Aquacal offers a 5 year full warranty on parts and 2 year warranty on Labor.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
