Thread: chlorine venturi
    Oct 2010
    Melbourne FL
    12
    chlorine venturi
    Thanks to this board I have been able to monitor and log the levels of my pool for several months.
    It turns out the chemicals needed are somewhat consistent barring heavy rains and extended periods
    super sunny days.
    I am wondering why finding a self contained liquid chlorine (non CYA) injector system is so clumsy or hard to come by.
    I understand chlorine will damage any moving parts and has too be added downstream from the equipment.
    SO... here comes the newbie ignorant question 2:...
    Why cant I put a secondary flow with a venturi to suck the liquid chlorine then regulate the flow and thus the amount of chlorine with a simple and inexpensive PVC valve?
    http://www.redbaronpoolsupplies.com.au/ ... s/2625.php
    The tube from the chlorine container to the venturi can even be fitted with a small check valve or the regulator to a saline drip.
    11000ish gallons, cartridge filter, IG (in ground), plaster, 1.5 hp pump, screen enclosure
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: chlorine venturi
    This is what I did and others have to used it for chlorine injection as well.
    Homemade Acid OR Chlorine Injection System
    If you inject the chlorine at a slow enough rate such that the FC rise (1-2 ppm) is not much more than the residual, it should not have an effect on the equipment.
    Mark
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Your desription is pretty close to the Hasa Liquidator that many of us use.
    Guest
    I have a Liquidator with the 3/8" upgrade and I am very happy with it. Sal runs a RolaChem with a chlorine supply and is happy with it. Both of them work well for our pools, which are each about 25,000 gallons.
    Those are two good options which are well received and work. I'm not sure why you would want to try something else that may or may not work, but if you do, let us know how it goes!
    susa's Avatar
    Oct 2010
    Deep South
    578
    not hard at all but typically the USA sold products are too pricey. If I did not have a SWCG system, I would have ordered this unit.
    I bought their simple PH controller (see my sigline for link) and they shipped it in 1 week from day of order from Italy to USA, installation was simple and it works great. Price was a little below $200.
