Thread: Pool losing water
    Pool losing water
    Hi guys, I think I have a problem.
    Looked out today and it looks like there is a foot less water in the
    pool then this time last week. It's already down below all the side plugs and
    approaching the top of the light housing. It's seems to be dry everywhere above ground so I
    don't know what to think. Besides floor drain or a big crack someplace.
    Thoughts and suggestions very welcome. I'm thinking the only thing I can do is
    let it go to see where/if it stops draining.
    Help!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Pool losing water
    If the water level is below the skimmer and returns, then your best bet is either the pool light or the main drain. Is there a valve to shut off flow from the main drain? Also check the waste outlet on your filter. That is another common spot to lose water. If you cannot readily identify where the water is leaking from, allow it to leak past the pool light. If the leak stops around the midpoint of the light then that probably is where the leak is. Try and squirt some food coloring around the light and see if it goes behind there.
    Love TFP? Become a
    TFP Supporter!
    The valves to the main drain are closed and the way I have the plumbing plugged there is no way water can get back to the waste outlet. I don't know what's up. I really hope it's just at the light box. I would think I would see some wet soggy earth with all that water coming out in a week.. Should I freak out about this or just let it go?
    Well it's past the light and it's still going down. I'm going to start pumping it out this afternoon and
    also going to try and get the cover off. So either my bottom drain/return line is shot or there is a crack someplace.
    That I'll know once the cover is off. My question is, what are the dangers of having a drained concrete pool in the dead of winter?
    My goal is to get it drained, plug the floor holes and try to get water in it as soon as possible. I also thought about just keeping it drained and
    maybe doing an acid wash it come warmer weather.
    Thoughts and suggestions please...
