Thread: Handheld/Portable TDS Meters
    Anyone with experience with these units - good/bad.
    Thanks
    55,000gal+/- salt water, DE filter, Pebble. Yes it is that large.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Handheld/Portable TDS Meters
    Not really, but my question is why do you want one? TDS doesnt really give you any useful information. You are much better off using a high quality drop based test kit to measure your water parameters.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Guest
    We use them for our business. They are ok for a quick reading, but not very accurate at multiple scales. Our probes scale is 0 -10,000 ppm. Example, if TDS is between 4,000 and 5,000 ppm our meter is fairly accurate. If I want a reading between 8,000 - 9,000 ppm, forget about it. Same goes for 0 - 250 ppm, not very acccurate. They have more accurate probes that read uS, but are very expensive, or an older Myron L Company analog type meter.
    Quote Originally Posted by salp
    Can you PM me with the make/model?
    Thanks
    Guest
    I will later tonight
