Thread: Hayward Preflex filter
    I have found a Hayward Preflex filter in my area and no pool company can answer questions about it. Hayward site talks about putting DE in it and how well it filters, but I cannot get an answer about using it with my SWG. Does anyone have or have used one of these filters and what kind of results can I expect from using it. I have an 18" round above ground pool that did very well this year but would like to replace the old sand filter I was using.
    Thanks for all your help.
    8000 gallon, sand filter, above ground,3/4 Hayward pump
    Oct 2010
    Georgia
    317
    Re: Hayward Preflex filter
    Which model Hayward Perflex filter? DE40AC or the DE50AC
    What is the size and flow rate of your pump?
    There should not be a problem with using a SWCG and a DE filter.
    Do you have a specific concern?
    Here is a comparison of Sand filters to DE filters:
    pool-school/pool_filter_comparison
    If your pool "did very well this year", why are you looking to replace the filter?
    Proper water chemistry and a correctly sized sand filter are an excellent combination for sparkling clear water.
    In normal daytime lighting, you may not be able to see the difference in water clarity between Sand and DE.
    At night, in a lighted pool, you can clearly see a difference.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
