Thread: can't I just drain the pool below the lines in winter?
    buzzbait00's Avatar
    Aug 2007
    North Alabama
    75
    I usually just run it when its going to get below freezing but their is a leak in one of the return lines above ground at the pump.All the lines are just about 1.5' below the surface.Can't I justdrain the pool below the lines in winter so the pipes dont freeze?Im in Alabama with a vinyl inground.
    36x18,MAYBE 27000gal?,VINYL.3/4 HP,PAC-FAB SUPER FLO SAND FILTER
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: can't I just drain the pool below the lines in winter?
    You can just follow the pool closing instructions in pool school. You'll want to cap your plumbing or you'll need to make sure the water level does not rise above the openings. Also make sure the pipes are blown out properly.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You have to blow them out and seal them, along with the skimmer line. Drain the pump and filter as well.
