Thread: adjusting actuator/valve cams
    Re: adjusting actuator/valve cams
    after 6yrs my valve stopped. when ordering valve purchased 2 gva-24 goldline actuators figuring the other maybe on the way out also. the problem i can get the in floor system to work or the water feature (overflow) but not both. prior to the new valve it did work. Please help
    26,260 gals. Gunite, IG, TA60 Sand Filter, 1HP, 3450 rpm's, 60 13.6 gpm. 25 year old pool
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Welcome to TFP. In order for us to help, we may need some more information about your pool. Is it possible for you to post a picture of your plumbing/filter/valve set-up?
    mas985's Avatar
    Pleasanton, CA
    11,743
    You probably just need to the set the cam position of the new actuator to the same location as the old one. Hopefully, you kept the old one. They should have included a manual which shows how to do it but if not, here is one.
    Mark
    tjhanks fpor replying the left side has the two pumps wisperflo 2 hp for pool 2 1/2 hp for spa, there is onne actuator and filter to the rioght is another actuator , pentair minmax 400000 btu heater propane , and auto pilot salt generator.
    right side of heater and the salt cell
    Nov 2010
    152
    For the life of me, I'll never understand why some builders insist on making the equipment maintenance areas so hard to access... . Yours isn't as bad as some I've seen, but if they turned the equipment around so it faced away from the wall, it's so much easier.
    The actuators come out of the box set to rotate 90 degrees, so if you wish to change this, you'll have to remove the actuator cover & adjust the cams to the same position that the previous ones were. As mas stated, the actuators should have a manual in each box, if not, he posted a link for it.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
