Thread: Maintain Temp Setting won't enable?
    Hello,
    Newbie here - brand new pool ... Jandy system with the AquaLink RS One Touch Control System. Have just turned on the heater for the first time .... trying to utilize the 'Maintain Temp Settings' but it will not enable. I have configured the 'Set Temp' for both the pool and spa and have the filter and heater running. When i try to set the 'Maintain Temp Setting' it immediately reverts to 'Off'. Any ideas on what i might be missing?
    Thx
    17kgal, PebbleTec finish, Jandy PureLink Water Purification, AquaLink RS, Jandy Stealth series pump, Jandy LXi Heater, DEV Series filter
    Re: Maintain Temp Setting won't enable?
    Just figured it out - was hitting the Select button instead of the scroll buttons.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Welcome to TFP!
    Thanks for posting the solution. If you did it, somebody else will do it soeday as well, and they might find your answer.
