Results 1 to 9 of 9
Thread: What is the best color LED that has highest light output?
    Central Florida
    84
    My Polaris D'light color changing LED pool light finally bit the bullet a couple weeks ago. While I was somewhat satisfied with it for the past 4 years I felt that it really didn't produce enough light. So now is the time to make a switch and would like the recommendation of your experiences with other colored LED's. I 'd really like to get the best one available that will produce the greatest light out put.
    Just as an FYI the Polaris D'light is a screw in LED bulb. Thnx
    18k free form IG w/spa (4 jets), Paramount in floor cleaning system, Starite system 3 filter, Jandy 2hp ePump, Sta-Rite SR400LP Maxi-therm propane heater, Jandy aquapure/apurem 1400 SWCG, Jandy automation PS4 w/PDA, IntelliBrite 120v 5-G LED pool & spa lights, 2" piping and (3)4x12 (5)4x10 Fafco Sunsaver Solar Panels.
    Oct 2010
    Georgia
    317
    Re: What is the best color LED that has highest light output?
    What size is your pool (approximate square feet)?
    Which D-light model do you currently own (12v or 120v)?
    The all White LEDS offer better illumination than the color changing models.
    Nexxus Com makes a white light only bulb that is as bright as 375 watt incandescent bulb. Priced around $300
    Pure White offers an LED light that is equivalent to a 300W incandescent and has a 3 year warranty. Priced a little over $300.
    The color changing bulbs, while not as bright, offer fantastic light shows.
    The Polaris PL120 bulb is designed for up to 450 square feet and the replacement is around $300
    J&J Color splash's new 3g bulbs are brighter than their 2g series. 2g's are around $200 and 3g's are $300
    Don't forget to change the lens gasket when you change the bulb.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Central Florida
    84
    See my sig for any info, but IG pool is approx 14-18K gal and the current D'light is the 120V.
    Central Florida
    84
    Ok, I now have to decide what LED light to use. I have seen many positive on the Intellibrite and while it might be a little more expensive I'm thinking the Intellibrite will give me the most brightness. Any opinions on the Intellibrite or even the Hayward Color Logic?
    Nov 2010
    152
    Not long ago, I attended a party at the home of a friend who had the Hayward ColorLogic. Attending the party were a number of other people, several of whom had different colored lighting (Jandy, Polaris, etc.) It seemed that they were impressed with the brightness and features of the Hayward and expressed that it did things that theirs couldn't do. Yes, it's only one example and opinions vary, but I took this as high praise for the Hayward, which was also the first LED on the market & still seems to sell far more than the competitors.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
    South Central NJ
    3,192
    The IntelliBrite wins. It's lens also distributes the light far better.
    See this link. It was a comparison by a builder using a box mounted niche to set the two in the same pool.
    http://ths.gardenweb.com/forums/load/po ... 10796.html
    Scott
    Owner of - PoolGuyNJ LLC
    Feb 2011
    Pennsylvannia
    17
    Anyone have pics of their Jandy Water colors?
    20x41 Roman style w/reverse radius corners, Automatic Pool Cover , Jandy (LXi heater, CL480 Filter, 2sp FloPro 1.0 hp, Aquapure SWG, Water Colors LED Pool Light, AquaLink RS8, AquaPalm, iAqualink, Polaris 9300
    Central Florida
    84
    Well after suggestions from PGNJ and the pool tech we've used over the years I must say I am totally happy with our new Pentair IntelliBrite 5g. When I first turned it on at night after install I was amazed with the brightness and spread of this LED, by far alot brighter then our old screw in D'Light. Well worth the price.
    anyone have any pics????
    22,000 In-Ground Vinyl Fox Pool
    250,000 MiniMax Pentair natural gas heater
    4 returns 1 skimmer 1 main drain
    1hp Hayward Max Flow II single speed
    Sand fox pool Filter
    First year owner of the aforementioned.
