I have the Zodiac Tri Pro (Australia) and I have similar problems with continuous chlorine generations. The technical staff suggested calibrating the orp sensor when chlorine was at 3ppm. This made no difference at times it would continue making chlorine and at other times it would stop and chlorine levels drop below 1ppm. At this point I needed to intervene to get the unit to make chlorine. I also have been using 20 litres of acid every 2 months and also baking soda to push TA up. The pool is now about 6 months old.
As the unit I have cannot be put in a percentage mode, I need to get a differenet module should I be going back to manufacturer to try and get a swap.
