Thread: best type of Vac head?
    What does everyone use? Ive been using an Astral vac head like this.
    Problem is that it doesnt have a brush/bristles on it just a flat rubber seal.
    Any ideas?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: best type of Vac head?
    What kind of pool surface?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    It really depends on the surface. You don't want to roll the vacuum across a vinyl liner in an above-ground pool; it may leave tracks that will fill up with fine silt and be even worse.
    I use one that looks like yours. Not so hot in the corners, but that's what the brush is for. I find slow movement works best, sorta sneak up on the dirt and let it get pulled in rather than pushed away by turbulence.
