Thread: How do I know if the seals need to be replaced?
    jabsaw's Avatar
    Apr 2009
    Anaheim, CA
    36
    When I went to start the pump after a filter cleaning, the motor hummed so I stopped it. I tried to start it again and it started up. Whew.
    I had to stop it again because it was not priming and I poured some water in the strainer basket and sealed it all up.
    I flipped the switch and I got a rattling sound and no water movement.
    WHAT??? So I stopped it to think and started it one more time to verify. Yep. rattle with no water movement. Ugh.
    I stuck my fingers in to feel if the impeller was moving, and it moves freely.
    I have a Hydramax II from Leslie's, 1 HP. No idea how old, we purchased the house 2 years ago with little to no history.
    Do I upgrade to a new 2 speed motor or replace the motor or just replace the seal?
    What do you guys think?
    [center:30izqb54]Jennifer[/center:30izqb54]
    1) 25,000 gal 2) DE filter 3) In ground 4) Pebble
    22,553
    Re: How do I know if the seals need to be replaced?
    Unless it's leaking, your problem isn't a seal. If it's rattling or squealing it's most likely bearings.
    jabsaw's Avatar
    Apr 2009
    Anaheim, CA
    36
    Bearing...does that mean a new motor?
    22,553
    Maybe, maybe not. If the motor still runs but isjust making a noise then it might be possible for an electric motor shop to just replace the bearings and the seal while they're at it.
