Thread: Storing waterfall pump.....plugs for pipes?
    Jul 2007
    Allen, Texas
    80
    Hi all,
    I'm considering uninstalling my waterfall pump for the winter, to save the electricity when it runs below freezing. I know I'll have to blow out the above ground lines, but I'm wondering if there are "plugs" which can be screwed into the open ends of my piping (the ends that normally connected to my pump). The pump is a Jandy 1.5 hp Stealth pump. Worse case, I could cover the ends with plastic bags or something similar, but a plug would be better (and I could drill/mount a bike tire valve in one, to aid in blowing out the lines).
    Mike
    Mike
    16.5k IG gunite pool/spa, pebble-tec type plaster, Aquapure 1400 SWG, Jandy 2hp ePump main pump, Jandy 1.5hp Stealth on waterfall, Polaris 280, iAqualink wifi control, Colorsplash LED pool/spa lights
    22,544
    Re: Storing waterfall pump.....plugs for pipes?
    They make expandable plugs for just that purpose. Search for winterizing plugs and you'll find plenty. They make different sizes to match your pipe sizes. They even make one with a schrader <sp> valve already in it.
    Jul 2007
    Allen, Texas
    80
    Thanks Dave.....I found the plugs easily online, based on "winterizing plugs", but haven't found the one with a schrader valve. I'm going to also check the local HW store for a possible plug that I could drill myself for a schrader valve.
    Mike
    Jul 2007
    Allen, Texas
    80
    Quick update: I searched around locally for a screw-type plug (like a PVC sewer cap) that I could screw to my pipe ends, where the pump used to be connected (inlet and outlet). However, Jandy's pumps have a odd sized connection.....it's not 3" or 4", but something inbetween and is a size not stocked in standard HW stores (I checked at Lowes and Home Depot). I shouldn't be surprised. I did find winterizing plugs that would fit inside the pipes themselves, but I wanted something I could screw on the end and also drill a hole in for blowing out the lines.
    Solution: 3" rubber sewer cap (with screw down strap). These caps have enough stretch that they will fit over the ends of the Jandy mounts glued to my pipes. I drilled a small hole in one that I can insert my rubber air blower attachment from my air compressor. This allowed me to blow out the lines, and then I just put a piece of electrical tape over the hole I drilled to keep any dirt out until I remove the cap and reinstall the pump in the spring.
    Mike
    Nov 2010
    152
    As a good Texas fellow, I can't imagine why you'd opt for that fancy electrical tape, instead of gool ol' duct tape! But don't use the Camo color, since you might not be able to find the pipe again in spring.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
    Jul 2007
    Allen, Texas
    80
    Haha.....duct tape was considered, but I couldn't find my roll of it (my kids use it all the time), so electrical tape won the day.
    Mike
