Results 1 to 9 of 9
Thread: TA test turns blue not red
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    486
    Well, I've decided to close my pool this year after last year being such a bear. I'm now trying to get my water balanced in order to do that. I had to be out of town for about 3 weeks so testing didn't get done. When I did to it, my numbers were the most out of whack they've ever been.
    FC 30
    CC 0
    T/A ?
    CYA 100
    pH 8.2
    I immediately turned off the SWG since it looks to be working overtime! I say ? on T/A because the test turns blue, not red; in fact, it went from blue to yellow. So I took this to mean that there was none and put in the required amount of baking soda to bring it to 80. Then about an hour later I put 1 1/2 cups of acid in to bring down the pH.
    Two days go by and I retest (yesterday). The FC has come down to 21 but the T/A still turns blue...no yellow any more though. The pH is still 8.2. I'm getting ready to go out and put another cup and a half of acid to lower the pH. Can anyone tell me what the problem is on the T/A? The pool is being closed tomorrow. Is this going to be a problem if it doesn't get resolved?
    Thanks for your help!
    Karen
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: TA test turns blue not red
    With the TA test, you are just looking for a color change to determine the level. The blue-yellow colors are what you get with high chlorine levels.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    486
    Oh okay...thanks John! So if I just get my pH level down I should be good to go right?
    10,700 gal IG vinyl
    2 skimmers
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by midtngal
    ...So if I just get my pH level down I should be good to go right?
    With an FC of 30, you will get a false high reading on your pH. Your pH test is once again reliable once your FC falls to below 10 or so. Let your FC come down before doing anything else.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    486
    Well, I'm closing my pool tomorrow so will it be okay to just leave it be until the Spring??
    10,700 gal IG vinyl
    2 skimmers
    30,431
    The short answer is "Yes."
    Your pH is almost surely in the 7's which is fine and your chlorine is high enough that you should open to a clean pool. I am assuming the pool water is visually clean now.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    486
    Dave, yes, the water is crystal clear. I hope you are right about opening to clear water. I've had such great luck in having no algae issues in the 3 years that I've had the pool, it would be a bummer to have to battle that in the Spring.
    Well, I'm all closed up for the winter...how depressing. Thanks for your help once again.......
    Karen
    10,700 gal IG vinyl
    2 skimmers
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hi Karen
    Slap the cover on your pool, fire up the 'Frozen Concoction Maker', turn up the Buffett and pray for an early spring!
    I hope to still see you around over the winter
    "With a little love and luck..."
    Luv& Luk
    -Ted
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    486
    Hi Ted! Guess I have no choice but to follow orders! The cover is on so I guess I need to fire up the "Frozen concoction that helps me hang on" machine!
    I'll see if I can be a little more present this year..........seeings as I don't have a pool to worry about, I'm sure I will have nothing to do!
    You guys are the best!
    Karen
    10,700 gal IG vinyl
    2 skimmers
