Thread: Old Pool Light Flange Problem - Extender available?
    Working on existing 35 year old pool. New plaster, tile and coping will be done. Existing light niche/can is damaged and I'm trying to avoid removing and replacing due to expense, etc. Only outer flange is damaged, specifically the old screw flanges are rusted off and gone so I have no way to secure new light that I've purchased to replace old. Is there an aftermarket universal ring/adapter that I can install when re-plastering that will allow for new light install?
    Can't locate anywhere if there is?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Old Pool Light Flange Problem - Extender available?
    Welcome to TFP
    Perhaps some of our resident pool experts may be able to assist, but it would be really helpful if you could post a picture of the niche/light assembly so that folks can perhaps give you an idea or two.
    Nov 2010
    152
    There's a product called a "light wedge" which will work thru the screw hole on the light itself & is fairly secure unless the kids bump the light frequently. There's also a "light adapter ring" that may work better, you can see both here http://www.aqua-man.com/itemMatrix_a...roupCode=M1140.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
    Thank you all...
    Here is a link to the requested picture....sorry but photobucket rotated it for some reason. You can clearly see broken screw flange.
    http://i1219.photobucket.com/albums/...r777/photo.jpg
