Thread: PH Testing
    PH Testing
    Wondering about this which I came across at work today. Hopefully someone can tell me if this would work for testing my pool or not.
    http://www.thermoworks.com/products/pH/ ... _8682.html
    Kurt R
    35900 gal. 20x40 Inground, Vinyl Liner with Deep End in the Middle, Roman Stairs on Both Ends
    Sta Rite Sys 3, Hayward 1.5 Super Pump, Aqua Heat Heat Pump, Paramount in Floor, BBB
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: PH Testing
    You'd need to get the 8682 at $75 to have something that is at least as accurate as the phenol red test (actually more accurate, according to their specs). The 8680 at +/- 0.3 is not good enough while the 8681 +/- 0.2 is marginal -- usually you can figure out the pH from the phenol red test to within +/- 0.1 with its in-between readings on the K-2006 (every 0.2 pH units). You'll need to do calibration periodically using the buffer solutions (probably the 7 and 10 since the pH will usually be above 7). This ain't cheap, but if you want something with a digital display, it seems OK.
    There's also the Hach Pocket Pal pH tester with an accuracy of +/- 0.1 pH units and a cost of around $57.
    However, if you are just testing pool water, you don't need a wide-range tester and could instead use something like the LaMotte ColorQ though that does a lot more than pH and costs more as well.
    Feb 2008
    Denton, TX
    5,061
    Re: PH Testing
    Most of the folks on here will use and advocate for the use of drop-based tests over electronic testers. They are cheap, easy to use, don't ever need calibrating, and give results that are easy to confirm if need be.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: PH Testing
    Ditto, plus all you are truly in need of is to ensure you're water is in the 7.2-7.8 range. I just make sure that if the Phenol Red test is closer to 7.8 I add some acid to bring it down to around 7.4 or so
    Re: PH Testing
    Thanks everyone for the replies, sometimes it seems that I have trouble reading the color test. I had a trouble free pool all season so I guess why fix what isn't broken
    Kurt R
