Results 1 to 9 of 9
Thread: Trichlor pucks & toilets
    Prav's Avatar
    Nov 2010
    Miami, FL
    94
    Got the hang of the pool maintenance and know the evils of pucks due to CYA. So what do I do with the tablets I inherited from previous owner? Can I just drop them in the toilet tank and use it as disinfectant? They seem similar to 2000 Flushes Blue and other similar products, and I probably don't have to worry about CYA buildup since the water is guaranteed to be refreshed on every flush.
    Thoughts?
    Thanks.
    14'x30' (est. 14K gal) w/spillover spa (est. 500 gal) - 1995 // Diamond Brite Blue Quartz - 2006
    Hayward SwimPure Plus T-15 - 2013 // Zodiac MX-8 - 2013
    Plain ol' Intermatic mechanical timer // Pump: 1˝ HP Pentair SuperFlo - 2012
    Filter: Hayward C17502(S) Cartridge Filter - 2011 // Heat Pump: Sunrunner/Aquapro 1300 (127K BTU) - 2011
    Guest
    Re: Trichlor pucks & toilets
    I would think you are ok as long as you are not on a septic system... You might have a strong chlorine smell in your bathroom.
    susa's Avatar
    Oct 2010
    Deep South
    578
    horrendous wear on cast iron pipes
    May 2009
    Dallas, TX
    782
    Quote Originally Posted by susa
    as well as the flapper and other components within the tank...
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Jul 2010
    northern California
    235
    So are the trichlor tablets much more potent than 2000 Flushes Blue and other chlorinated toilet cleaning tablets?
    IG pebbletec pool: size of pool: 27,000 gal; filter: cartridge - Hayward Superstar Clear; pump size: 1.5 HP; TF 100 Test kit - got it on 7-29-10; The Pool Cleaner-4-wheel suction model; Pool calculator: http://www.poolcalculator.com/; bleach calc: http://troublefreepool.com/files/BleachCalc262.exe
    Mar 2007
    San Rafael, CA USA
    12,082
    2000 Flushes® Bleach has this MSDS that shows that the tablets are mostly DCDMH which is the chlorine analogue to bromine tabs. The pH of a 1% solution is 3.6 so these are quite acidic. Trichlor tabs have this MSDS where the pH of a 1% solution is 2.7-2.9 so is about 10 times as acidic. The Trichlor may dissolve too quickly as well -- the 2000 Flushes® product apparently lasts for up to 4 months whereas Trichlor will usually dissolve in a week. It is the very slow rate of dissolving of 2000 Flushes® that probably keeps it from making the water too chlorinated or too acidic.
    Jul 2010
    northern California
    235
    Thanks for the info, chem geek.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Most new toilets come with a warning now which states that the warranty is voided if you use cleaning tablets inside the tank so even those are considered hazardous to the toilet let alone trichlor pucks.
    Mark
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Just hang on to them and use them over a weekend or vacation away.
