Thread: Need to increase TA & CH during rainy season?
    Jul 2010
    northern California
    235
    Hi everyone,
    I need help in determining if I should do something about the TA and CH in my pool. Here are the test results:
    PH - 7.8
    FC – 17
    TA - 70
    CH - 240
    CYA – 40
    CC – 0.5
    Water temp – 50 degrees
    FC went up substantially since I have been using a few trichlor tablets while we were away for a few days when the temperature was still in the 70’s. The weather changed drastically during that time. It went down to the low 30’s at night and 50’s during the day. It has been raining quite a bit too so CH decreased from around 330. Based on the pool calculator, the CSI for the above test results is -0.21. Do I need to be concerned about that? Thanks.
    IG pebbletec pool: size of pool: 27,000 gal; filter: cartridge - Hayward Superstar Clear; pump size: 1.5 HP; TF 100 Test kit - got it on 7-29-10; The Pool Cleaner-4-wheel suction model; Pool calculator: http://www.poolcalculator.com/; bleach calc: http://troublefreepool.com/files/BleachCalc262.exe
    30,419
    Re: Need to increase TA & CH during rainy season?
    I wouldn't change anything. Perhaps monitor your pH carefully as you don't want it any higher but that's it. How does the water look?
    Feb 2008
    Denton, TX
    5,061
    You are ok at -0.21. In fact, you don't really have much corrosion potential until you get to a CSI of -0.6. Keeping it a little bit on the negative side is ideal anyway. Like duraleigh mentioned, just watch your pH as this is the most easily adjusted of the values pertaining to CSI.
    Jul 2010
    northern California
    235
    Great, I will keep an eye on the pH. It kept increasing in the summer. I am hoping by using some trichlor tablets, the pH will stabilize a little. The water is crystal clear just as it was in the summer since I took over maintaining the pool chemicals.
