Results 1 to 7 of 7
Thread: Pool volume?
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    Pool volume?
    Getting ready to have this pool built. Can you smart people help me figure out how many gallons of water are in this pool? Will follow up with photos of the construction that starts next week.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    Nov 2010
    Calera, Al
    271
    Re: Pool volume?
    Hope this helps, Good luck with the new pool.http://www.pentairpool.com/pool-owner/r ... olcalc.htm
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Nov 2010
    Midland, Georgia
    353
    Re: Pool volume?
    Thank you for the link. I'm just not sure how to calculate the grecian shape since the pool isn't exactly rectangular.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pool volume?
    I get 22,000 gallons. You can just break up the pieces then add them up.
    Mark
    Nov 2010
    Calera, Al
    271
    Re: Pool volume?
    You Could try to call Joey Eiland???? Since he is the designer that would be my first stop unless you know someone who is good @ geometery.... You would calculate the volume for a rectangular pool 27'x15' long,then calculate volume for each end section as a rectangle and you would subtract the triangle volume for the corners. I am sure someone has an easier way though....
    Nov 2010
    Midland, Georgia
    353
    Re: Re: Pool volume?
    Quote Originally Posted by mas985
    Thank you sir.
    Nov 2010
    Midland, Georgia
    353
    Re: Pool volume?
    Rob N, I asked Joey and he said it was around 22,000 but he would double check and get back to me.
