Thread: Intro
    Just want to be polite and introduce myself. I have received some good info here and of course I now have a dilemma which I posted about in construction and repair. Anyway I'm a mom with a mermaid for a daughter and that's about it! Cya round. Char
    20*40 Liner 2'-8' deep, Spill Over SPA, Electric Cover, Jandy Purelink (Aquapure & PDA), Hayward SP2610x15 (1.5HP Single Speed), Hayward H300 (Millavolt)
    Houston, Texas, USA
    Welcome aboard! I think you will find that TFP is the premier pool forum.
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
    Hi and welcome to the group! A Mermaid...that's cute.
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Butterfly's Avatar
    South Carolina
    Hi Char and welcome
    You're done SLAMing when:
