Thread: Help! new electric box installed, pump not as powerfull
    Jul 2010
    Fredericksburg, VA
    24
    I had an old electric box and upgraded the box to a new one. Now my pool pump does not have the same humming noise, it seems that it is pulling less water. In addition, the pump itself seems to be running hot. Any ideas?
    Guest
    Re: Help! new electric box installed, pump not as powerfull
    What is the pump voltage? is it 110V or 220V?
    TFP_wanna_be's Avatar
    Orlando, FL
    129
    my guess is it was reconnected as 110V vs the desired 220V - just a guess... Do you have any test equipment? Volt meter etc... Test the voltage at the motor...
    My Intro Page: tfp-wanna-be-checking-in-t27499.html
    20K Gal IG Pool - Resurfaced 11/14 w/ Super Blue Diamond Brite
    I test with TF-100 and SpeedStir
    1.5Pentair / 36sq DE filter
    Polaris 380 (love this thing)
    Guest
    That's where I was going!
    Dec 2009
    Central Massachusetts
    2,690
    If it's wired at 110 VAC, I can understand the increased amount of heat since its pulling more current. However, the fact that is is potentially pulling less water doesnt make a lot of sense if the only thing that has changed is the VAC it's running on. It should still spin at the same rpm. Unless the resistence is so high and the wattage is lowered enough that it doesnt spin as fast. That shouldnt be, but stranger things have happened.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
