Results 1 to 14 of 14
Thread: Would someone have a picture of Acid Pump setup ?
    susa's Avatar
    Oct 2010
    Deep South
    578
    Am considering adding automation for Muriatic Acid using an Acid Pump.
    As the space is limited on my pad outside and since I am in the process of building a new enclosure for all the new gear (everything installed in last 30 days), would be interested in seeing a picture or two of how you route the lines from the Acid Pump into the system.
    Am assuming many people here are using various types of automation feeders to maintain PH.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Would someone have a picture of Acid Pump setup ?
    I don't use an acid pump but I do use a passive acid feeding system which is shown in this thread. Others have made a few modifications including using needle valves for flow control.
    Mark
    susa's Avatar
    Oct 2010
    Deep South
    578
    Thanks, read entire thread.
    I am leaning strongly toward purchase of SIMPOOL PH.
    Will have to figure out the details, perhaps have a buddy in EU buy it and ship privately.
    mas985's Avatar
    Pleasanton, CA
    11,737
    If your acid use is somewhat predictable, you may not need the controller part and could get away with a peristaltic pump on a timer. Ebay will sometimes have peristaltics for reasonable prices.
    Mark
    solarboy's Avatar
    Aug 2010
    Europe
    337
    [attachment=0:ai6g2nop]IMG_2996.jpg[/attachment:ai6g2nop]
    There you go, I have this myself and have been very happy with it.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Jul 2009
    London and France
    574
    And the pipe is connected downstream of the filter into the return pipe with a saddle clamp and injector.
    susa's Avatar
    Oct 2010
    Deep South
    578
    could it be connected to the pump using the already existing small drain plugs by using a small adapter for icemaker from Home Depot ?
    ...or is there some "rule" that specifies they must be connected "after the filter" ?
    I already have the IC40 Cell connected "after the filter".
    susa's Avatar
    Oct 2010
    Deep South
    578
    solarboy,
    would you have an area view, showing all the bits on the pad, including where the lines come and go ?
    thanks.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    [attachment=0:20mvp38w]IMG_0023.jpg[/attachment:20mvp38w]
    I've circled in red the saddle bracket which is where the acid is injected and the sensor is placed (on the return line to the pool). The image shows the sensor removed and hanging off the yellow pumping unit as the pool has been drained for tiling.
    I have the container of acid located behind the pump house rear wall outside, as in other installations I've noticed that the acid fumes cause corrosion in the pump area.
    susa's Avatar
    Oct 2010
    Deep South
    578
    Is the 220/230/240v electrical connection using two hot 120v and one ground, ie 3 wires for power ?
    Is there any need to handle the sensor delicately, ie. does it require special cleaning, calibration, etc?
    Jul 2009
    London and France
    574
    Quote Originally Posted by susa
    Susa, you may be able to buy a seko version, the Seko pool basic PH which comes at as a complete kit.
    In Europe our mains supply is 220-240v so we just have phase (live) nuetral and earth, not two 120v supplies.
    Yes, probes need to be treated with care and should not be allowed to dry out so the plastic protection cups should be replaced when the probes are removed. Occasional cleaning and replacement is also needed.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    I'm sure a 220/240V to 110V transformer would be pretty easy to come by as it is only a 2 to 1 winding. The tip of the probe has a cap which is filled with water during storage. It came with some calibration solution but I just measured the pH in the pool and adjusted it until I was getting the correct pH.
    susa's Avatar
    Oct 2010
    Deep South
    578
    my entire pool equipment pad is wired 240v 60hZ as the existing equipment (in sigline) demands it. thus I envisioned the Simpool PH would be simple to hookup to already existing line.
    I don't have 120v connection(s) at all outside.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    You'll be fine then.
