Thread: If I cover the pool do I have to close
    Jun 2010
    San Antonio
    424
    I am in South Texas and we will have overnight lows in the mid to high 20s a few nights a year. Most days it will warm to 40s and certainly above freezing. I have a 7,500 gal ABG that is protected from wind. In the past I simply cut the pump time down and left the pool uncovered. However, the leaf drop is very heavy and it is difficult to keep the pool clean. Every spring it is a huge job to get the leaves out. This year I want to cover the pool. Since the cover is not hard it will be floating on the water. I would like to continue to do what I have done in the past - rely on circulation to keep from freezing, but am concerned about the cover blocking the skimmer and also water level getting too low and I not knowing it. What would you guys do in my situation?
    As always, thanks.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    22,549
    Re: If I cover the pool do I have to close
    Your plan will work but you will have to make sure the water level doesn't get too low in the skimmer. That's easy to do though. You should be able to look into the skimmer and check and add what you need to. Since it'll be covered you won't have to worry about evaporation very much.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    I did that the first year with my above ground pool. Just like Bama said, check the water level inside the skimmer and run a hose through there to top off if needed. You may want to raise the water level up a bit as extra insurance. With the cover on you won't be skimming debris off the top so you can keep the water higher.
    In the spring be sure to get all the nasties off the cover before you try to remove it. We didn't and the cheap cover I had tore and dumped all that mess in the water. It went from clean to green in about 60 seconds.
    Love TFP? Become a
    TFP Supporter!
    Jun 2010
    San Antonio
    424
    Thanks Dave and Zea. It will sure make it easier to not have to blow and put antifreeze in.
    Larry in Texas
