Thread: Rubber return plugs
    Aug 2008
    Delaware
    45
    Rubber return plugs
    I cannot fit most of the rubber plugs into the returns while blowing air through the pipes.
    I am so frustrated! Any other plugs that would be easier for me to handle?
    Seem like the rubber plugs expanded from last year. Thanks for any help
    Susi
    30X14 IG,Vinyl,13,800 Gal
    Hayward-Pro Series Sand filter(Rated flow75GPM/284LPM)
    SWG-Aqua Comfort,Polaris360 Auto Vac
    LauleaHere&There's Avatar
    Aug 2010
    Rural Moloka'i, Hawai'i
    155
    Re: Rubber return plugs
    I have used wine bottle stoppers as return plugs in a pinch. But only to tweak the plumbing, never for a "blow-out".
    12' round above ground pool. 3,500 gal. Vinyl liner. Waterway Supreme Hi-Flo 48 frame pump. 1.5 hp. SWG. Sand filter with Zeobrite.
    Thanks, members of Trouble Free Pool, for being so friendly and informative!
    Mar 2007
    Coastalish 'down easter'
    4,160
    Susi, I've seen this often enough and feel your pain
    What may have happened is that the plugs were left compressed over the summer and lost some of their elasticity OR, you just can't provide enough torque to get them to seal, a pair of pliers would help with this
    If the returns are threaded, you can use a Hayward SP 1022-C with a couple wraps of Teflon tape to seal them (the 1022-C is a 1 1/2" threaded plug with an o-ring -- other companies also manufacture them and they're all the same, so go with the less expensive ones BUT do Teflon tape them! )
    These plugs can be tightened with a flat-head screwdriver so that you know you've gotten a good seal
    Luv& Luk
    -Ted
    Aug 2010
    155
    Sorry, I really misunderstood the question.
    Never mind.
