new Pentair Intelliflow VF variable speed pump, running 24 hr/day at 15 GPM, about 128-135 watts, 900-1250 RPM.
every few hours, perhaps 4 to 6, the pump switches into Priming Mode from Running Cycles mode (pump programming is set to Start Cycle 00:00 and End Cycle 23:59, thus it is on 24 hours day)
there are no visible air bubbles but of course the basket is not full to the top of the clear top as the water flow is automatically so slow.
when it re-primes, it revs up to 450 watts and 1350 RPM for a couple minutes and then automatically throttles back down to speeds above.
normal behavior?
normal behavior?
