Thread: Test kit tip
    Test kit tip
    I don't know if this a problem for anyone else but I live in Florida where it is perpetually humid. When I first got my test kit, I was having a hard time with the little scoop. Despite being careful to keep my hands dry when using it, the powder was always sticking to the scoop. So I used a Q-tip to clean it out one day, and ended up leaving the Q-tip in the little compartment with the scoop. Ever since I left it in there, I have not had to use it to clean the scoop. Just being in there, it seems to absorb the moisture so that the powder does not stick.
    Next time I come across a packet of silica gel from something, I think I will toss it in the kit. Can't hurt, eh?
    18' round Sharkline Matrix AGP / 8600 Gal. / sand filter / Aqua Trol SWG
    Pool owner since 2001. Thanks to TFP for helping me convert off Baquacil after six years!
    ktdave's Avatar
    Katy, TX
    Cool tip. I also collect a huge amount of dust on the scoop. Will have to try that.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Houston, Texas, USA
    I can relate to the humidity. Good tip, I'll try that. I rinse the scoop off ater every use. Also I have three scoops (having ordered more powder), so I cut the scoop end off of one, and use the paddle end to level the powder. I hope this makes sense 8)
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
