Thread: What do you do before a freeze
    Jul 2010
    Houston,TX
    38
    I live in Houston, TX and was wondering what I should do before a freeze. Do you just keep the pump running 24/7?
    17,000 gal in ground with spa, wet edge surface, Paramount PCC 2000 in-floor cleaner,Pentair Clean and Clear Plus 520 Cartridge filter, 3 hp Pentair Intelliflo VS SVRS pump , waterfall with 1 1/2 hp booster, Del ozone Eclipse1 ozonator, puck feeder. Borates added 8/2/2010
    Feb 2008
    Denton, TX
    5,061
    Re: What do you do before a freeze
    If you don't have freeze protection, then yes, run your pump until the freezing weather subsides. There are timers that can be had with integrated freeze protection built in as an option and they will automatically start the pump once the temperature hits a certain point. You might check in to that.
