Thread: Convert Single speed Whisperflo to Dual Speed Motor Only
    May 2009
    NJ
    21
    Hey guys
    I need to replace my existing Whisperflo 3/4 HP motor. It has an AO Centurion motor. The pump basket is in very good condition. I'd like to go to a 2 speed AO Smith Square Flange Pool Motor - E Plus Centurion - High Efficiency - .75/.1 HP - 230 Volts - Stock Number B2980. Would this motor directly bolt into the existing basket and could it use the existing impeller? Any problems with such an installation? Would the 2 speed switch be on the motor itself (I'm aware it doesnt come with one) or does it mount somewhere else? Thanks for any help!
    Jim
    15k inground pool/spa
    3/4hp Whisperflow
    Cartridge filter (Hayward)
    Boostapal: http://www.boostapal.com/
    Pacifica's Avatar
    Mar 2010
    San Diego, CA
    47
    Re: Convert Single speed Whisperflo to Dual Speed Motor Only
    You should be able to install the new two-speed motor onto your existing pump. The only thing that changes is that you'll have an extra load line coming off of the new motor. You'll need to have an automation system to change the speed automatically otherwise some motors have a manual switch on the back of the motor.
