Results 1 to 14 of 14
Thread: Unplug terminal from IntelliChlor when adding salt?
    susa's Avatar
    Oct 2010
    Deep South
    578
    from the recommended chem page:
    Salt can simply be dumped into the pool. Spread it around a bit with a brush so there aren't any large piles, and leave the pump running for 24 hours after adding salt. If you have a SWG, it should be turned off while you are adding salt and for the next 24 hours.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Unplug terminal from IntelliChlor when adding salt?
    Dont worry about that, it's wrong. I'm not sure who wrote that, but you can ignore it. I have an intellichlor just like you and I leave it on all the time when I add salt.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Just FYI; the salt reading will probably go a little haywire for a day or so after you add salt...just give it time to settle down.
    susa's Avatar
    Oct 2010
    Deep South
    578
    ok.
    If for any reason it needs to be shut off, just a matter of unplugging the cord from the transformer power unit (the cord from the IC40 Cell) ?
    (edit: read manual, it says to disconnect power, then unplug)
    Jul 2007
    Brisbane, Australia
    874
    you need to turn it off if you add salt to skimmer basket to avoid damage from high salt concentrations
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Quote Originally Posted by Strannik
    How does high salt concentration damage the SWG?
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Jul 2007
    Brisbane, Australia
    874
    Quote Originally Posted by benavidescj
    overloads the transformer
    if you dump lots of salt in the skimmer basket the salt concentration in the pipes and conductivity of water increases almost immediately and becomes very high, so cell starts drawing lots of current.
    if the unit doesn't have overload protection - the transformer is guaranteed to burn out. if there is overload protection - you might be lucky and it might turn the unit off before the damage is done.
    Dec 2009
    2,690
    Good to know, but i'm not sure any directions I have ever seen say to dump 40+ pounds of salt down the skimmer suction
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    If you are adding salt for the first time (large amounts), turn if off for a day. If you are adding maint amounts (a bag) you can leave it alone. The unit is easy enough to turn off, the manufacturer tells you to turn it off, what could be easier?
    With the iC 40, you shouldn't unplug the cell from the box unless the power to the box is turned off. In other words, if there are any lights on, don't unplug the cell.
    And i would never add salt to the skimmer. If any manufacturer suggests doing that in print, i'd like to see it.
    Factory Warranty Station for:
    Jul 2007
    Brisbane, Australia
    874
    adding it to skimmer basket allows it to dissolve faster
    i wasn't aware that any manufacturers actually tell you where exactly to put salt.
    some tell you not to put it in the skimmer box, probably to prevent what i have described above from happening
    Dec 2009
    2,690
    I wouldnt add salt thru the skimmer. No way.
    susa's Avatar
    Oct 2010
    Deep South
    578
    interesting replies.
    how about pre-dissolving the salt in a large plastic trashbin for a few days until liquid and then dropping that at the deep end of the pool ?
    Dec 2009
    2,690
    Quote Originally Posted by susa
    You could, but it isnt needed. Just dump it in and brush it around. In reading all your posts over the last few days, I think you have a good handle on what your doing. I aslo think that you are overthinking some of this a little bit. For a new pool owner, that usually happens. Try to relax and just go with it.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,730
    What BK said..I just walk around the pool in the evening and pour the salt around the perimeter...it's dissolved by the morning...and that's using water softener salt which is much coarser than pool salt.
