Thread: Wild swings in PH on new pool, Diamond Brite
    susa's Avatar
    Oct 2010
    Deep South
    578
    am currently on day # 13/14 since starting fillup of new pool, Diamond Brite surface.
    was given directions to keep PH at 7.0 for 30 days as ..."...it will help the surface to cure hard... brush daily..."
    pool was acid washed before fillup and I ran old system (old pump, old filter) for about 10 days to collect most of the dust that brushing caused to flow into the lines.
    PH is daily easily over 8.0, add 1 gallon muriatic acid and it's down to 6.8 - 7.0, is this quite normal for a new surface ?
    new system is now running 24 hours/day, pump is set to 122 watts, 15 GPM and circulates water
    have added just liquid chlorine and muriatic acid, nothing else but I do have on hand baking soda, borax and cyanuric acid and of course salt (..but salt will have to wait until January..)
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Wild swings in PH on new pool, Diamond Brite
    A full set of test result would help narrow things down, but it is perfectly normal to experience frequent PH rise while the plaster cures. It will get worse once you kick the SWG into action, but eventually the plaster will cure and your TA will drop down to a level, which will stabilize PH.
    susa's Avatar
    Oct 2010
    Deep South
    578
    this morning
    PH 6.6
    TA 30
    I added one 72oz/4 lbs box of Borax which brought PH up to 7.2
    Since TA was low, added baking soda and measured couple hours later at 60, will wait until tomorrow to make any changes while system continues to run (pump on 24hr/day)
    22,550
    Which test kit are you using?
    With a TA of 30 your pH is going to have a tendency to swing wildly. You did the right thing by bringing it back up a little.
    Dec 2009
    Central Massachusetts
    2,690
    As an FYI, when both the pH and TA are on the low side, you can use washing soda instead of borax to raise the pH. Normally, we suggest Borax to raise the pH since it doesnt have much of an effect, if any, on TA. And most of the time you want to increase the pH but leave the TA alone. In Susa's case, adding ~3 pounds of washing soda will raise the pH to the same 7.2, but also raise the TA by 20 ppm as well.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    susa's Avatar
    Oct 2010
    Deep South
    578
    now, 8 hours later, after my initial mixing and adding, Leslie's tests:
    Water Temp:72 F
    CH: high
    Phosphates: 0.5
    TA: 70
    PH: 7.0 (this is actually where I want it to be!)
    No cyanuric acid, which I am aware of and will slowly be adding.
    Have only used liquid chlorine last 14 days, slowly adding muriatic acid to keep PH and now this is the first time that Alkalinity is almost where I want it, will add a little Sodium Bicarb tomorrow to bring it to 80-90.
