Thread: New pump installed, is it strong enough
    Dallas, TX
    227
    I previously had 2 hp motor that came with the pool when we bought the house. It was an old Centurion.
    Old Pump:
    New Pump label:
    Setup:
    All my specs below are accurate except for the pump, which i haven't updated to the 1.5 pump yet.
    Is this enough pump to get the job done? I was at work when the install was done and checked when i got home and noticed it was only 1.5. Plan on calling them tomorrow to ask about that and if they replaced the seal between the motor, because i read that is a must when replacing motors. I have used this company for other pool issues and they have always done a good job, but i thought i would seek advice on here as well.
    Thanks in advance!
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: New pump installed, is it strong enough
    It looks like it should have plenty of power. I would ask if they replaced the seals and impeller.
    Love TFP? Become a
    TFP Supporter!
    22,548
    While that 1½hp pump will be fine on a 21K gal pool, it's more about the pump model than the pump size. Different pumps have different flow rates at different heads. As I said, any 1½ hp pump is gonna be fine unless you're running solar 3 stories high.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Dallas TX
    183
    Did they replace the entire pump, or just the motor?
    If the entire pump, you should be fine.
    If just the motor, you now have a 2.5hp impeller being spun by a 1.65hp motor... Correct?
    33k Gunite, CompuPool CPSC48 SWG, Sta-Rite System 3 DE, 2.25hp dual-speed, POOLVERGNUEGEN Pressure-side
    Dallas, TX
    227
    Quote Originally Posted by acroy
    Sorry they just replaced the motor, but did change out the impeller and the seal.
    Nov 2010
    152
    It's likely that your pump was oversized a bit to begin with. If they reduced the size of the impeller to match the 1.5hp motor, it should be fine. If they left the original impeller in place, it could be a problem. I'd have them replace one or the other as the motor size should match the impeller size.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
