Thread: discontinued DE filter grid replacement
    ssa's Avatar
    San Jose,CA
    26
    I have a Leslies's DE filter from my previous owner. It is very old.
    The filter grid screen has been ruptured so now it is spitting
    dirt back into the pool.
    I went to leslie's try to find a replacement grid. It turn out this
    filter is long discontinued. The closest it got was call Wet Institute,
    36 sqt, stainless steal. There are still some Leslie store has the
    filter grid replacement for Wet Institute. Even the replace grid is
    also discontinued.
    My closest store is having the other out of state store send the last
    few piece to their store. It will be about $220 for 8 piece . But a new
    filter will likely run $600 without the installation.
    Should I get that replacement or just replace the whole filter? Those
    replacement grid are likely been store for a long time.
    On the other hand, the filter works fine before the screen rapture. And
    it is likely my fault causing it. I have been pushing my luck of not cleaning
    the filter for too long.
    Any other idea is that, it is possible to DIY replace the screen on the
    filter grid? The skeleton of the grid is still OK, nothing breaks. The screen
    is make out of some sort of fiber glass cloth I guess. If I can get hold of some
    of those screen cloth, I should be able to stitch a bag to fit the filter grid.
    Has any one done that before or I should just cough up a new filter?
    Thanks
    15x32 vinyl, IG,17K gal, DE filter, Hayward 3/4 HP pump, Hayward Ultra Vac, Solar cover with reel
    SportCount LapCounter, FINIS SwiMP3.1G
    Enjoying my pool thanks to TFP.com
    Oct 2010
    Georgia
    317
    Re: discontinued DE filter grid replacement
    SSA
    The filter was manufactured by Atlas for Leslies.
    If you have the model DE-36 the Unicel replacement grids should fit The Wet Institute DE filter.
    A set of grids for the 36 sq ft model will cost you about $135 plus shipping if you are willing to do it yourself.
    http://www.poolandspastuff.com/GridWetInstitute.htm
    Most of the parts are still available, but they are expensive. If the filter is otherwise in good condition, I would simply replace the filter grids.
    http://www.inyopools.com/pool_parts_wet_institute.aspx
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    ssa's Avatar
    San Jose,CA
    26
    Thanks for the tips.
    I have open the filter to clean it many times so I don't mind replace it myself.
    The filter is so old that it does not have a back wash valve. I have to do it the painful
    way every time, opening the filter. I guess that is possible one of the reason
    why the grid ruptured.
    ssa's Avatar
    San Jose,CA
    26
    Just an update.
    I get all 8 filter grid replaced. It is all good now. My pool is clean again.
    My DE filter does not have back wash valves. I have to open the tank
    to clean it. I just find out that using the shop vacuum to suck the water
    out of the bottom of the filter tank works wonders.
    Oct 2010
    Georgia
    317
    Thank you for the update.
    Glad the replacement grids solved your filter problem and at a fraction of the cost of a new filter.
    poolschoolgrad
