Thread: closing leak
    Jul 2008
    Bucyrus, Ohio
    108
    closing leak
    closed and covered our 15 AGP and drained to about 6" below return, that was about a month ago. Having checked it the other day, I find that I have only about 1-3" of water left. I live in Ohio and winters can be pretty harsh. What are the chances of the walls holding up over the winter with that little of water in it? Not sure what to do cause I cant add water to it all winter.
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    22,539
    Re: closing leak
    With 1 to 3" of water left that leak is going to be real close to, if not in, the bottom. I don't have any advice for you. I know you don't want to repair it and fill it back up just to leave it covered. Maybe someone else can give you advice about what to do.
    Dec 2007
    Central New York
    504
    Re: closing leak
    With 1 to 3 inches of water left, get in and find the hole. Repair it and fill the pool.
    My 2 cents
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: closing leak
    if you can't find any holes to patch i'd lay your winter cover in the bottom of the pool and add water to that to try to get some water in the pool to act as some kind of support
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Dec 2007
    Central New York
    504
    Re: closing leak
    I wonder what he ended up doing? I hate to think he just let it go.
    Hotrod30
    Pentair VF3050 pump
    Jul 2008
    Bucyrus, Ohio
    108
    Re: closing leak
    Quote Originally Posted by Hotrod30
    Actually we did just leave it...its covered and with all the rain and snow...and melting off and on all winter the pool has held up just fine.
    planning on buying a new liner in a few days and then search for someone to install it.
    Overwhelmed
