Thread: How does Backwash work in VF pump with Cartridge Filter ?
    susa's Avatar
    Oct 2010
    Deep South
    578
    pg 17 of the Quick Start Guide (IntelliFlow VF)
    A Rinse cycle is automatically executed after the Backwash cycle. ....you need to set the Backward Flow and Duration and Rinse Duration.
    When using cartridge filters, the backwash cycle must be performed when cleaning or replacing filters.
    What does that mean? Does the pump start running Rinse Backward Flow or what is this telling me takes place? Am I not to shut down pump when doing a rinse of the cartridge?
    South Central NJ
    3,192
    Re: How does Backwash work in VF-3050 with Cartridge Filter ?
    Cartridge filters are not backwashed so you won't need to use this. I expect it a typo.
    Scott
    Owner of - PoolGuyNJ LLC
    susa's Avatar
    Oct 2010
    Deep South
    578
    PoolGuy,
    Thank you, I note however that the manual for the VF and the programming requires one to enter something into this section of the program.
    Just enter 1 minute or Zero time?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I don't think you need that program at all. Just turn off the pump, clean the carts, then turn it back on when you're done.
    Nov 2009
    Indialantic, FL
    323
    I don't own a VF (went with a VS), but I think from looking through their manuals the OP is correct.
    There has to be some setting so the pump can execute a rinse to reset it's internal "clean" pressure level. It can be as short as a minute I think, but that's all I recall - probably time to give Pentair Customer service a call and have them walk through the settings for a cartridge filter.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    susa's Avatar
    Oct 2010
    Deep South
    578
    Hmmm.... the thing is, the programming setup must be done, so quite certain the section does require a value, otherwise it would not be in the Quick Start Guide, written in USA (not India, not China, not Japan)
    Have to keep on researching or call Pentair.
