Results 1 to 12 of 12
Thread: Rusted Skimmer screws
    Evansville, IN
    65
    Our Salt water pool is only 4 months old. The screws that hold the skimmer on the side of the pool are already rusting and bleeding down the side. I just talked to our Pool installer this morning and they said it was the "metals" in the water that are causing the rust. They pretend there is nothing they can do. I think they are using the wrong type of screws. What is the truth? What can I do?
    36X18 Inground Pool, SWG, Hayward Pump, Hayward gas heater, Undertrack Auto Cover, Interfab basketball system, TF-100 Test kit, Polaris 9300 Robot Cleaner, Pool Completed July 29 2010
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Rusted Skimmer screws
    You're right. They used cheap screws and need to replace them with the correct stainless steel screws, but it really might be easier just to do it yourself.
    Evansville, IN
    65
    Where would I buy the replacement screws? Lowes, Home Depot? I called them back and they claimed it was a "faulty" screw. I said all 4 were faulty? They stated they would come out in the spring and replace them. Right.
    Oct 2010
    Kansas City, MO
    14
    I'm having the same issue on our newly built pool. The PB said they will bring out a cover plate so we couldn't see the screw heads. I'm not sure, but that doesn't seem to solve the issue, just mask it.
    I'll probably just change them out myself next spring.
    Shores
    17,000 Gallon Vinyl-lined In-ground Sports Pool
    Triton II Sand Filter; WhisperFlo Pump
    Pentair Intellichlor Electronic Chlorine Generator Model IC40
    Ray-Pak Gas-Fired 250,000 BTU Pool Heater
    Polaris 380 Automatic Pool Cleaner with Booster Pump
    EasyTouch Control Panel
    Save-T 3 Automatic Pool Cover
    3 Skimmers, 3 Inlets, No Main Drains
    Vero Beach, FL
    462
    You need Titanium or 316 Stainless Steel screws. Don't bother with 304 SS. You can get them from mcmaster.com or a good local hardware store (probably not HD or Lowes).
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Mar 2007
    Coastalish 'down easter'
    4,160
    I've ranted ( ) on this in the past. Are the skimmers Hayward?
    Apparently there's some bad stainless screws out there Good quality stainless steel screws will fix the issue. If there's rust on the faceplate a little rubbing with vitamin C (ascorbic acid) will remove the stain
    By no means simply cover the faceplate without first replacing the inferior quality screws
    I've usually seen the light screws rust out first so take a look at them too. Also, SR Smith ladders seem to have been cursed with inferior stainless washers - check those as well
    Make no mistake, the salt shows the poor quality ss more quickly than a pool who's salinity is below ~ 1500ppm.
    Luv& Luk
    -Ted
    Evansville, IN
    65
    Yes, Hayward skimmer.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    When you replace the screws check the old ones with a magnet. SS typically has a very very weak attraction to magnets [depending on what grade]. Sometimes you can barely pick up a SS screw with a rare earth magnet. In other words it shouldn't look like this picture of my magnet stuck to non-stainless steel step screws. "Hey look they are rotting away! who would of thought! lol"
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Evansville, IN
    65
    I am still trying to replace the rusted screws on my hayward skimmer plate. I have tried mcmaster.com, but I have no idea what size I need. My plate has 16 holes. Any ideas?
    Apr 2011
    Warner Robins, GA
    245
    I dont know, but you could take one out, bring it to Lowes or HD and slip on the right nut, then you will know the size and pitch.
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    Evansville, IN
    65
    I tried that and could not find any match. I'll take a screw to a local nut and bolt company and see if they have some stainless screws that are the same.
    Apr 2011
    Warner Robins, GA
    245
    Quote Originally Posted by sd72667
    Did you try both standard AND metric? It has to be one of those sizes!
