Thread: Pump run time in Winter
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    all, is it still necessary to get 1 or 1.5 of water turnover per day in the winter time? if i'm paying for electricity when i shouldn't be i'd sure be happy to cut that back some.
    any feedback is appreciated!
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    22,542
    Re: Pump run time in Winter
    If you're leaving the pool open then I wouldn't go much below 1 turn a day. Having said that, You can run it less and less until you start seeing some cloudiness then bump it back up a bit.
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    ok, thanks bama! i currently have it set to where it turns over approximately once per day.
    Once I cover mine I turn the pump off until it gets cold enough to freeze and then I start running it again.
    25k gal vinyl AquaRite T-15
