Results 1 to 12 of 12
Thread: Portable pool vacuum/filter system
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    I made this the other day for doing pool cleanings. Each year more and more customers ask us to clean the pool at the opening. I used a 1hp hayward superpump. A hayward c500 single cartridge filter, 1.5" plumbing, 2 unions, a 3-way valve and a cheap $30 hand truck from Homedepot. I installed the 3way valve so we could either vac the pool through the filter or out to waste. Guess we could use it to drain a pool too if we had to. Just figured id share in case anyone was interested in making one. I couldnt figure out a way to mount the filter to the cart so i just used a rachet strap and it worked out perfect!
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Portable pool vacuum/filter system
    I like it. Simple, but perfectly functional.
    22,553
    I agree perfectly functional. With a little creative plumbing you could sit the filter on the cart, but as long as it works for you who cares,
    SW Georgia
    300
    I like it, thought of doing the same thing myself.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Guest
    Here's a link to some other ideas, if anyone is interested: http://www.poolgeniusnetwork.com/forum/ ... uum-setups
    Mar 2007
    Coastalish 'down easter'
    4,160
    Good job, Kevin
    The ones I've played with in the past (and NONE of them were a pool companies) had welded a plate for the filter to sit on, and bungied it to the handcart.
    If you know a welder, that might make the filter a little more secure
    If you don't mind my asking, how much was the rig you set up? (I'm thinking of making something similar and would appreciate an idea of how much it would cost)
    Luv& Luk
    -Ted
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Quote Originally Posted by waste
    Good job, Kevin
    whos kevin? lol lol
    Ill PM you. I get all equipment cheaper then online prices since i own a service company.
    COMPANY INFO BELOW
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Quote Originally Posted by simicrintz
    Link ask's for password. Looks like i good site. Just signed up
    COMPANY INFO BELOW
    Guest
    Quote Originally Posted by Heckpools
    It is a good site, Matt, but not nearly as active as this one. It is more geared to those in the industry, unlike this one which is obviously geared towards the homeowner. I've learned more on this site than over at PGN, but I do check in over there now and then also. You might make some good contacts there, and you will recognize a few from this page there as well.
    Apr 2014
    VA
    1
    How do you wire the pump to accept a 12V heavy duty cord? I'm guessing it needs to be a three way cord?
    Any suggestion would be great!
    Aug 2014
    houston, tx
    1
    Great set up, looking for something like this to vacuum after soda blasting tiles. Where is the top pvc running to and connected to.
    May 2015
    patchogue
    1
    Hello hope all is well, would you be able to provide directions and parts needed to put one together just like this one. What size pipes are needed and the types of unions, valves etc. I already have old Hayward pump that i would like to utilize as pool vacuum pump for in ground pool. also if you can provide close pictures of this units I would greatly appreciate it. This image does not show the top portion of the fillter and rest of the white pvc piping. Thank you in advance.
