Thread: Hooking up an all new Pentair system w/SWCG next week
    susa's Avatar
    Oct 2010
    Deep South
    578
    pool is 15,000 gallons
    am told by rep to initialize with 240 lbs of salt (4 bags @60 lbs each).
    system will be Pentair IntelliChlor IC40 and after new Diamond Brite all I've done is maintained PH at close to 7.0 and added liquid chlorine.
    read somewhere that 120 lbs would be enough to initialize pool but suspect the crew knows better and my mind is like cheese full of holes....
    22,551
    Re: Hooking up an all new Pentair system w/SWCG next week
    Has it been at least 30 days? (60 would be better)
    Have you used the Pool Calculator to figure out how much salt you are going to need?
    susa's Avatar
    Oct 2010
    Deep South
    578
    no, it'll be 10 days next week
    you're suggesting to wait (I can do that) to initialize the salt system?
    I could always install all components but not turn on the IntelliChlor control center.
    Pool Calculator does not work for me, perhaps due to the operating system and type of browser I use
    Guest
    Yes, you need to let the plaster cure, 30 days minimum, If you can wait 60, it would be better!
    susa's Avatar
    Oct 2010
    Deep South
    578
    ok, will wait 60 days then.
    I assume there is no harm to the IntelliChlor IC40 components in circulating no-salt load as long as the control center is inactive. Of course there is some salt naturally even from liquid chems but I will not dump my salt into pool until January.
    Thanks.
    22,551
    Waiting is the best plan. It won't hurt the SWCG to run the water through it before you add the salt. Yes there is some salt but it insignificant compared to the amount of salt the SWCG requires to operate. I'm surprised your PB didn't tell you to wait.
