Thread: Leftover chemicals
    Leftover chemicals
    It's been an uneventful summer and I am thankful! I have a few gallons of leftover liquid chlorine which I store in an unheated location. Will it freeze?
    Redding Connecticut, Wagner pool 50k gal. cement. DE filter requires 9 pounds of DE to restore. 9ft deep kidney shaped.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Leftover chemicals
    Don't bother storing it! I don't have the numbers on it's breakdown in front of me, but it won't be much more than colored water come spring!
    I'd either use it in the pool or use it over the winter to clean your toilets and bathtubs [I use diluted 12.5% to spray down my toilets and all the areas in my showers that show the pink biofilm common in the North East]
    Liquid chlorine (sodium hypoclorite) breaks down to ~ 1/2 strength in ~ 240 days [when kept in a cool and 'sun free' area] The breakdown is quicker when the % is higher, but... bottom line is to use it before you loose it
    You can also use it to get rid of mold or mildew on decks, etc.
    Have a great winter - I hope we'll still see you here in the cold months!
    Luv& Luk
    -Ted
    Jul 2009
    London and France
    574
    Quote Originally Posted by waste
    Wow long winters down your way
    Mar 2007
    4,160
    And I just moved further north
    Luv& Luk
    -Ted
    Thanks! Didn't know.
    Mar 2007
    4,160
    De Nada!
    One other reason not to store chlorine inside is that it will outgas and start attacking any metals in the room
    Luv& Luk
    -Ted
