Thread: Quick question on CH
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    my question is very similar to acroy's recent post. i ran a full battery of test today with the TF100 with these results:
    FC 11.0
    CC 0
    TC 11.O
    PH 7.5
    TA 70
    CH 410
    CYA 75
    TEMP 60
    Water VERY CLEAR
    trying to get my SWG adjusted to lower the chlorine a bit but based on the pool caluculator it's at the high end of the range. currently running the pump 10 hrs a day with the SWG set at 10% (adjusted today). pool calculator indicates a CSI of -0.52 which if i'm understanding CSI is still in the acceptable range.
    what i'm concerned about just like acroy is the CH. it was up around 400 a couple of months ago and then we had 7 inches of rain in one day and that dropped it back down to 290. it's been on the increase since and just want to clarify if anything needs to be done at this point to lower the CH.
    as always, thanks for any feedback!
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Quick question on CH
    Do not worry about lowering the CH unless the saturation index starts to get much closer to zero and even then it's not a big issue unless you start to see scaling in your salt cell which won't be an issue soon since it will be shutting off when the water gets colder (probably around 55ºF or so). Why is the CH rising so much? Do you have a lot of evaporation and refill with high CH water?
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    i'm not quite sure what's causing the rise in CH. over the summer i added water probably every other day or every 3rd day at least. i was afraid i had a leak somewhere but when i did the bucket test, it indicated there was no leak. we did have a very hot summer here in north texas though. i only add water now maybe once a week at most.
    Dallas TX
    183
    we had a LOT of evaporation this summer & fall; drives the CH up pretty quick. you can probably dial down pump runtime unless you're using it to clean while the leaves fall...
    33k Gunite, CompuPool CPSC48 SWG, Sta-Rite System 3 DE, 2.25hp dual-speed, POOLVERGNUEGEN Pressure-side
    30,419
    Test the CH of your fill water to see what you're refilling with. It's probably fairly high naturally.
    The best safeguard against scaling is controlling the pH. Keeping it not much higher than where you are will prbably preclude any calcium issues.
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    thanks all for the quick feedback. i agree we had a lot of evaporation over the summer and so far this fall. it does seem to be easing somewhat though. i have always tried to keep the PH around 7.5 for the most part and will continue to do so. thanks again!!!!!!!!!!
