Thread: cleaning debris off bottom inside the Liquidator
    terriolsen's Avatar
    Jun 2007
    Huntington Beach, CA
    25
    I've seen it mentioned several times in researching The Liquidator, but I've not come across exactly how to do it. Do what? Clean the debris off the bottom of the LQ! When it gets 1-1/2 to 2 inches thick (every 6 months or so as it says in the manual), what do I do to get rid of it?
    10,000 gallon Pebble Fina Grigio, Pentair FNS Plus 60 sq ft DE filter, WhisperFlo Dual Speed 3/4 HP pump, IntelliBrite LED Light, The PoolCleaner, 8 gal Liquidator
    22,551
    Re: cleaning debris off bottom inside the Liquidator
    I block the inlet tubing off and use the suction tubing to suck most of the water out of it and then dump it down the floor drain and rinse the tank out.
