Results 1 to 7 of 7
Thread: which variable speed pump?
    Can someone please advise me on a good, reliable variable speed pump to replace my hayward 1cv superpump?
    Thankxxx
    22,543
    Re: which variable speed pump?
    Pentair VF. Lot of people like them.
    I was looking at that a year ago, but was told that it was for a more complicated system than mine. Also, that the electronics break down a lot. Any truth?
    22,543
    There haven't been of a rash of reports about problems with them. They seem like a reliable product.
    susa's Avatar
    Oct 2010
    Deep South
    578
    am installing this one:
    Pentair Intelliflo Variable Speed Pump VF 3.2kw 3HP 230V
    just setup a 3-breaker subpanel with 240v supply for the pump today.
    now on to find best price for the pump, tomorrow....
    Nov 2010
    152
    The Pentair VF or the Hayward EcoStar pumps are both pretty good. The EcoStar is a much more user friendly version of Hayward's original VSP. Very user friendly on programming and installation. It's also available in a VRS model for anti-entrapment features.
    APSP CST Certified
    17k inground concrete; 1.5hp 2 speed Tristar pump, 300sq.ft. Cartridge filter, AquaLogic PS-4 w/ Tcell-15, Navigator suction cleaner.
    Dec 2007
    Central New York
    504
    I have the Pentair VF-3050. That pump does more than I'll ever want it to do.
    My old Hayward pump ran at 2050 watts while the VF runs at 375 watts, were I have it set at 31 gals per min. (the 2050 watts was measured).
    It has a built in timer that does alot.
    The pump knows when the filter is full (you set the pressure) and shuts off.
    The pump knows if an intake line is blocked and shuts off.
    The pump shuts down for low voltage.
    It's a great pump.
    BUT
    Remember ... it has 2 inch fittings and I don't run the pump at a real low watt input and water output setting. I will not put a 2 inch to 1.5 inch fitting between the pump and the filter, (don't flame me cause I won't) so I also put in a new and bigger sand filter with 2 inch fitting.
    I just answered another post about the VF-3050 pump as to how I did it.
    what-is-the-amp-draw-on-pentair-intelliflo-variable-speed-t27747.html
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
