Thread: cloudy water
    Oct 2010
    Arizona
    9
    cloudy water
    Hi, I had a huge algae problem, it finally cleared up and now the water is super cloudy. I had this aqua chem testing kit. ( I will order a better one from here soon as I use these up)
    They suggest I put in a sink and sweep, it says it takes all the old dead particles and drops it to the floor to be swept up.
    My chemicals are as follows:
    TH 250
    TC7
    FC7
    PH 6.5ISH
    TA 120
    CYA 50
    i AM TRYING to switch over to the BBB method and I am not doing a great job yet.
    Does anyone know what I should do now to get the cloudy look out?
    12,000 gallon plaster diving pool. Hayward Pro Series sand filter.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: cloudy water
    It does take some time. You just have to keep the filter running as much as possible, backwash and sweep. I don't think I would put any more chemicals in the water. Did you happen to do the overnight FC test. I notice your TC and FC are equal which is good but you want to make sure you pass the overnight FC test. Also, your pH needs to come up some, it is low. Try to get it closer to 7.5.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Oct 2010
    Arizona
    9
    Re: cloudy water
    Do i buy some ph up or is there a bbb way to raise ph? I am sorry I am going to do the school again to remember but I have a lot of " ****" in life right now stressing me out and i can barely remember anything.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: cloudy water
    20 mule team borax raises PH...found in your supermarket grocery aisle
