Thread: source for refill reagents
    Oct 2010
    Cocoa, Florida
    6
    Any input on sources for refill reagents for my Taylor K2006 test kit?
    Fla Rizzo
    13000 gal 18x33 AG vinyl
    200 sqft cartridge / 2 hp 2 speed pump
    liquidator w/big bore mod
    Taylor K-2006 test kit
    Dec 2009
    Central Massachusetts
    2,690
    Re: source for refill reagents
    TFtestkits?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    bk is correct! Taylor and TF testkits use the same Taylor reagents. The packaging is different but the reagent identification numbers are the same. If you want to walk into a store and buy reagents, then you need to be careful. Most pool stores do not stock a complete supply of reagents and may try to sell you a different one. If they do not have the reagent you need then try another store or order it online. You cannot substitute one reagent for another. The tests are engineered for specific reagents only.
    Love TFP? Become a
    TFP Supporter!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    There are many different sources if you happen to just google the reagent numbers...some are cheaper than Tftestkits, yes, but given Dave Smith the owner of TFP is also the owner of tftestkits.net, that is where my business is and will be. His customer service is 2nd to none and should there be any issue with your order it is quickly remedied...no questions asked. Main reason you see most of us recommend using tftestkits.net. Besides becoming a TFP supporter, purchasing from Tftestkits.net sort of helps us keep Dave well nourished as well as support this cool forum
    Oct 2010
    Cocoa, Florida
    6
    Thanks, I just placed my order through tftestkits.net.
    Fla Rizzo
