Thread: Bubbles coming from pool light
    Ok,My first post,Just had my pool re-plastered and the guys that did the sandblasting broke the lens on the light in the deep end,they sent a guy out today and he replaced the lens and installed it back in the water.I turned it on and it worked fine but i noticed bubbles coming from it.At first just little bubbles and then it "burped" a big bubble and then back to little ones.I only get the bubbles when the light is on,nothing when its off.Is this normal? Is the heat from the bulb forcing air out somehow? Thanks in advance,Brian
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    Re: Bubbles coming from pool light
    I would say any bubbles coming from the light is a big problem. Have them come back out and check it out.
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
