Thread: cya drain
    cya drain
    I am a bit mystified by my test results regarding CYA. It was my understanding that you only reduced CYA levels by draining/refilling, but not by evaporation/refilling.
    This last April, my CYA was down to about 0, as it is most Aprils, so I bumped it up to about 40ppm. About a month ago, chlorine seemed to be getting burned off quickly, so I tested and it was almost down to 0 again!
    I bumped it back up to 40 at that time. I tested again today and it was 30ppm. I know that the CYA test is one of the least accurate, but I'm still mystified. The way I test is pretty consistent.
    I certainly didn't drain off any water. I live in SoCal, so we have a lot of evaporation, although this summer wasn't particularly hot. I do have a lot of aeration in my pool (25k/plaster).
    Any ideas why I would have a constant drain on my CYA level?
    Thanks!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: cya drain
    Do you have a autofill? You may have a leak.
    Guest
    Re: cya drain
    Unless your splashing out a lot, I agree dmanb2b, you might have a leak...
    Re: cya drain
    Quote Originally Posted by dmanb2b
    I do have an autofill. Any idea how to track down a leak?
    Guest
    Re: cya drain
    Shut off autofill first, then determine if you have a leak. You can do a bucket test. Use a 5 gallon bucket and fill it up to the same level as pool level (put bucket in pool). If your pool level ends up being lower then your bucket water level, you have a leak. Start with that first.
