Results 1 to 7 of 7
Thread: Spillover Spa Wall Top between spa and pool missing?
    I bought a house with an in-ground concrete ad tile pool with a matching spillover spa, and I can't tell you how valuable this website is to help me learn about my new equipment as a first time pool owner.
    My issue is the wall between the spa and pool looks like it is missing it's top; meaning, the wall separating the pool and spa consists of the pool wall for about 2 feet from the bottom, then 2 rows of 4 glass blocks, and that's it. It looks like at some point there was something on top of the glass block (it looks unfinished and rough) that maybe created a waterfall effect into the pool, but the piece is missing.
    Does anyone know if that missing piece can be replaced, and what the piece would be called, or will this have to be custom made? I have been looking all over the internet, but have come up empty so far on what it would even be called.
    Thanks in advance,
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,089
    Re: Spillover Spa Wall Top between spa and pool missing?
    Welcome to TFP
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    If you have glass blocks, I doubt there was anything on top. The roughness might be calcium scale. Post a picture.
    Sorry, I should have posted pics on the initial post. I tried to get a top down view of the block wall, but it's kind of hard to get a good shot of it. If I look along the wall of the pool/spa split above where the block wall is, I can see a faint outline of something that was about an inch thick (it's an outline of what looks like caulk or grout on the tile). The top of the glass wall just looks unfinished to me, you can see the rough spots on the top of the wall that kind of look like grout patches, but maybe that's the way it is supposed to be.
    I don't know about the spots but the pool is beautiful.
    1971 San Juan Fiberglass pool 12,000 gallons
    New Pentair Whisperflow 1hp
    New Pentair FNS DE filter 64sq
    All 1.5" piping and no heater
    1 skimmer, 1 main drain, and 2 returns
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    Ditto that.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Thank you, the pool was severely neglected by the prior owner, and I have spent a lot of time restoring it. This wall has been bugging me because it just looks like something is missing from the top. Given the neglect, I just assumed the prior owner broke something off of the top of the wall but haven't been able to find an off the shelf product that would go there.
