Thread: Soap Foam in Pool
    Aug 2009
    Bradenton, Florida
    11
    Soap Foam in Pool
    Just cleaned very dirty tiles in spa/pool with an acid based tile cleaner. Tiles turned out great but when I started the pool back up it created massive foam from spa to pool. Looks like a gigantic snowcone. Any remedies?
    8 K pool, cc 100 filter, Auto-Pilot SWG, 1 HP Whisper-Flo pump, in-ground gunite pool 9 yrs. old,solar heat and Pentair 250K heater.
    Re: Soap Foam in Pool
    Enzymes and shock it with chlorine.
    1971 San Juan Fiberglass pool 12,000 gallons
    New Pentair Whisperflow 1hp
    New Pentair FNS DE filter 64sq
    All 1.5" piping and no heater
    1 skimmer, 1 main drain, and 2 returns
    Feb 2008
    Denton, TX
    5,061
    Shocking your pool should take care of it I would think. First make sure that you pH doesn't need adjusting and then shock it.
    Aug 2009
    Bradenton, Florida
    11
    Thank you for your suggestions. I shocked the pool and let it run over night. Water was clear and foam free.
